Hello Fletch,
it looks amazing. Thats just what I was looking for. The idea with the shell is also great. I am new to rendering and still focus
on building accurate models. Hopefully I will get a feeling for the balance between accurate models/good render and almost accurate models/awesome render.
The shell doesnt really change the appearance of the model in SU but improves the render very much.
As for the normal, you were right. I didnt pay much attention to "normal" in your first reply because english is not my first english and
i didnt realize that you meant the face direction.
Now that I reversed the face it works like a charm and i feel a little dumb that I didnt realize that by myself.
Just copying the model that works was also on my mind but in the end it is very little use if I do not understand how to do it.
Once again I want to thank you for the amazing support and taking the time to help me (even though it was a dumb beginner problem with the normal)
Its good to know that there is a place where you can seek great advice. I think I will b e very happy with Twilight Render.
Best regards
niX.
Need help. Glass plate with LEDs
Re: Need help. Glass plate with LEDs
Here, it's even more simple, try the Realistic Glass>Plexiglass Template on the 5 visible sides of glass, then the bottom face as emitter facing into the glass block.
be sure the emitter does not touch the floor/share 3D space with the floor, because the floor can block the light.
- Test_PlexiGlass_LED_TWLsupport.skp
- (110.58 KiB) Downloaded 468 times
- LED-Glass-Plexiglass-Railing-Easy09.jpg (22 KiB) Viewed 7009 times
I didnt think it could get any better, but this seems to be perfect.
The "round" edges are pretty nice. I think they add to the realism because the light hits those edges even at the top of the glass pane.
The handrailing looks very promising too. I was thinking about a way to stabilize the panes in the next step and I think a handrail in
a similiar manner like you did it would work pretty well for the design.
You are really fast. Whenever I get a little step done I look at this thread and see that you have completed the next 3 steps already
But I am sure that I am going to pick up speed soon as I learn more about TwilightRender.
The tip with the emitter not touching the floor is very valuable. I didnt notice that before, but the floor did in fact block some light in my model.
Thanks!
Best regards
niX.
Thanks!
Best regards
niX.
glad to help.
This will render best with Easy09, best-looking, and likely fastest-rendering.
Light emitters and this type of glass material render quite slowly with biased render methods. But feel free to experiment. Be sure to use the Easy 1-7 settings you see with the + signs... this means the settings contain some "extras" in them that will aid in calculating some materials like caustics, etc.
See the Tips and Tricks master list for a full list of topics and you will find more about this.
- SketchUp: SU8
Nice work.. May i use this model in my works? (I draw just for hobby)
It is free for any use.
