Thanks for the encouragement and info. I will plug away for a while. But worth noting, I don't get much call for this, and I ain't no 'Solo'. So my renders will always be 'quick and dirty'. So for example, once I learn a way of getting the 'outside' right, that will be it, I expect.
BTW. Showed one of the renders to another client, she couldn't understand how I took a photograph without the wall! People don't LOOK!
Thanks Fletch, I will go thru all that.
NichChun, not meant to be night, failed to get light thru the door.
Re: 'Also most raw renders look a bit lifeless and need post pro'. Any topics you can point me at for simple PShop post-pro?
Attempt at a 'serious' render
Re: Attempt at a 'serious' render
I normaly make a bit more contrast in PS and look for levels to adjust the midtones.
well, actually, you have done very nice renderings here, you are not giving yourself enough credit.BTW. Showed one of the renders to another client, she couldn't understand how I took a photograph without the wall! People don't LOOK!
There are several tutorials on this subject in the Master List of ResourcesRe: 'Also most raw renders look a bit lifeless and need post pro'. Any topics you can point me at for simple PShop post-pro?
for instance....
[Post Production - Secret 1]
The client, God bless her, has made more changes, which is good cos it means I have to keep going.
Heres the latest, used a sky portal on the door, got rid of all the bumpmaps, they were slowing the render down too much and didnt do much anyway at this size. Made sure the whites weren't white, hid or deleted 'out of view' geometry. Need to play with the sky (strength?) to reduce the overexposure on the floor by the door.
Fairly happy with this, esp when compared to the first ones:) Example below.
- Easy 09. About 6 hrs
- 25.jpg (516.14 KiB) Viewed 9337 times
- Example of previous attempt
- Long-view-web.jpg (46.08 KiB) Viewed 9337 times
Wow, amazing progress looks more lightened. Watch for the HDRi to don't appear much brighter than the scene. The cabinet corner and the door low-end look to be very burned up.
Thanks Kronox, Not using Hdri, just a sky portal, tried reducing the sun a bit, below, but I'm inclined to think the previous one is how it would probably look on a bright Aussie day.kronox wrote:Wow, amazing progress looks more lightened. Watch for the HDRi to don't appear much brighter than the scene. The cabinet corner and the door low-end look to be very burned up.
Client has changed materials back to V2 now, we are now officially going around in circles:)
- Sun strength reduced. Easy interior, 30 passes
- 37web.jpg (53.55 KiB) Viewed 9332 times
looks very good now.
In my models I am using a sunset sphere outside for exterior. That is the best set for presentation, because interior lights can be switched on and there is something to see outside but not lit too much. (on a bright day interior lights ususally are swiched of)
If you take a photo of a room on a bright day, the exterior normally is overexposed and there is nothing to see except much light.
