V2 Tutorials Animated GIFs #gif #GIF
SketchUp: 2016-2021
Post by Fletch » Thu Jan 15, 2015 5:32 pm
Animated GIF files can at last be rendered in SketchUp with Twilight V2 - think flickering fireplace fires, or movies on TVs in your animated fly through.
GIF textures can not be directly placed as a texture in SketchUp so you will need to save a copy of the .gif file in a common image format like .jpg or .png. Then apply this image as a texture in SketchUp.
After this, apply a Twilight Material Template and load the animated .gif texture into the Color slot. Then render the animation using the Animation Render dialog.
Here are the detailed steps:
  1. Insert a copy of your animated .gif image that has been saved as a .jpg or .png format as a texture in your SU scene, you will likely need to apply a Twilight Template to the texture.
  2. Change the Color slot in the material from the default "SketchUp" to "Texture"
  3. Change the "type" of image texture file to search for .gif file types.
  4. Choose your animated GIF file that matches the .jpg or .png texture file you have inserted into SU's material.
  5. Set up your animated camera if so desired. For still camera, you will need to duplicate your scene, as scene transition time is what determines the length of your video.
  6. If you have set up multiple cameras, go to SketchUp pull-down menu "Window>Model Info" and set interval in seconds for your cameras, such as "1" second or "2" second transition.
  7. Open the Animation Editor/Render Animation Dialog for Twilight Render via the Extensions (Plugins) pull-down menu>TwilightV2>Animation Render
  8. Choose to Animate All
  9. Choose your desired render setting - suggested to use the Animation Render Settings folder.
  10. Set the length for your animation. This will be a function dependent on how many cameras you have and what transition interval you have specified in SU.
    Animation length explained: If the transition time is 2s and you have only 2 cameras, the length of the animation will be 2seconds. If you have 4 cameras, this is 3 transitions... so 3x2=6 second animation length.
  11. Choose a very low resolution for test rendering.
  12. Choose your framerate - default is 30 frames per second (fps) 5fps is recommended for test rendering. 24fps is movie theater film framerate 30fps is television frame rate.
  13. The animation will be rendered one frame at a time and saved in the format, and named, and placed in the location you specify under "Base Image Name"
  14. Hit Play to render the animation.
  15. After render is complete, open the image sequence in a video editor such as Quick Time Pro on Mac or Windows Live Movie Maker or Virtual Dub for Windows.
  16. Using the Video Editor > Save the animation as .mpg or .mov or .avi or other video format of your choice.
SketchUp: 2016-2021
Re: V2 Tutorials Animated GIFs #gif #GIF
Post by Fletch » Sun Apr 11, 2021 9:57 pm
Here's an animated TV scene as an example.
The image on the screen is a placeholder image, as SketchUp cannot read .gif files.
The animated .gif file is in the zip folder. You may need to edit the material in SketchUp with the Twilight Material Editor to point to the .gif file in the proper location on your machine.
:!: NOTE: Requires Twilight Pro
Render with Extensions>Twilight V2>Render Animation
ANIMATED-TV-Screen.zip
(2.26 MiB) Downloaded 91 times
ANIMATED-TV-Screen.skp
(304.97 KiB) Downloaded 85 times
