Low render preset
- SketchUp: 2018
Low render preset
So recently I've started to learn TR again... guess what... low render preset rocks !
Render time 410 sec.
Always thought that No. 09 is best option, but seems like i've underestimate all the others. Of course there are some limitation, but still such a nice picture with less than 10 minutes with postpro.
- SketchUp: SU8 to SU2019 Pro
Re: Low render preset
Nice result
Due to reasons of time, most time i use preset low
masloprojekt wrote:So recently I've started to learn TR again... guess what... low render preset rocks !
biggest noobie mistake is to jump to the higher presets before even trying out the "low" ones. For interiors like this one, "Low" should indeed be good.
- SketchUp: 2018
That is totally my case. I think that is because in progressive you can "see" effects faster.Fletch wrote:biggest noobie mistake is to jump to the higher presets before even trying out the "low" ones. For interiors like this one, "Low" should indeed be good.
- SketchUp: 2018
Exploring further advantages of biased presets. Below Living Room rendered with Medium+ and DOF in Post Pro using Depth Render
Not bad for an hour of rendering.
The color of the lights could be maybe a little more realistic. In the latest version of V2 you should be able to set the Kelvin temperature for the lighting - this info can be found for the light bulb or the light manufacturer's website. Subject: Color of Lights / Light Render Speed Comparison
- SketchUp: 2018
Thanks Fletch. That is what i've done. I was a little bit surprised, but afterwards i accepted results.
- SketchUp: 2018
It took about 5 minut (8 cores) to render each of the images below. The more I know it, the more I like it.
Does anyone know a proven way to simulate daylight in low presets ?
- Turn ON physical sky with sun at power/intensity/strength of 4 or 5 (default sun/sky is perfect.)
- Use Architectural Glass template
- Be sure that sun shadows in SketchUp are where you want them before you render
- Set sky type to Spherical, load a treeline spherical sky image, like the ones available for free in the Red Carpet Resources here on the forum
Increase intensity of sky a little to simulate that it's outside exposure, while you are inside the building. (If default intensity is 1.0, try 2.0)
