You will need your Product ID, which is the code that you received right after purchasing a license. With that, follow the directions below on the new computer.
If necessary, download Twilight Render V2 from our website at
http://www.twilightrender.com/index.php ... ds/upgrade and install on the new computer / OS.
To activate Twilight Render.
1. Launch SketchUp and go to Plugins pull-down menu
2. Select Twilight V2 -> Options
3. When the Options window opens, click on 'License' on the left-hand side
4. If you are using Twilight Render 2.6 or ealier, under 'Computer ID', click on the Copy button. (This is not necessary if using Twilight Render 2.7 or later.)
5. Click on the activation link. It will open a webbrowser and point it at our website.
6. On the webpage, into the appropriate place, paste your unique Computer ID (if necessary) as well as your Product ID, and choose 'Activate'.
7. Your activation code will be emailed to the email address you used when making your purchase.
8. Copy the activation code from the email and paste it, into the appropriate place, in the 'Edit Options' dialog box and activate the product.
9. Restart SketchUp.
