White spots or strange lights with High Setting
Posted: Tue Sep 12, 2017 8:49 pm
Sometimes when you render with Easy 06 High or Easy 07 High+ strange lights or odd spot lights or white spots appear in the image. This is due to low caustics settings.
If you are a Twilight Render V2 Pro user, you can easily edit the setting to create a version with Caustics disabled.
- Highlight/select the "High" easy render setting
- Choose to edit the setting with the edit button
- Find the Caustics value and set to "0" by clicking the red word "Value" and then unchecking the "true" box.
- Choose to "Save as" and place in this location giving it a clear name:
Windows: C:\ProgramData\TwilightV2\RenderSettings
OSX: "~Library > Application Support > TwilightV2 > Render Settings" - Then to render with the updated render setting press the "Refresh" button in the render settings pull-down menu
- go to the "Custom" settings to choose the updated setting as you named it.
