Page 1 of 2
animation with only sun moving.
Posted: Wed Oct 25, 2017 11:45 am
by archigraphe
hello,
I test rendering with only sun as light,
the purpose is to show the path of the shadow on wall......
So I procede like that, but this procedure seems to be wrong..
first scene : shadow on, shadow from sun, time begin 07:50
final scene : shadow on, shadow from sun, time ending 20:00...
I use 02b low aa2 as I have inox metal as indicate to me in an other post.
result : bing wrong specular color.... there is only 1 second between this scene....
- anim0001.jpg (40.58 KiB) Viewed 13376 times
- anim0002.jpg (42.22 KiB) Viewed 13376 times
- anim0003.jpg (42.41 KiB) Viewed 13376 times
the link to view fast rendering video :
https://drive.google.com/open?id=0B6hI4 ... 211R2hINWM
So....what is the good process , or what is my error ?
Thank you all.
Re: animation with only sun moving.
Posted: Wed Oct 25, 2017 11:56 am
by archigraphe
I've just testing rendering with
No sun environment (deactived)....same error,
No shadow from sun.....same error...
Strange effect......!!!!
Posted: Wed Oct 25, 2017 11:57 am
Render with Animation render settings.
Render Settings>Express>4)Animation
Set floor to "Flat" material template.
Try in Environment to enable "Corrected Shadows" check box. Be sure Sun Enabled And Sun Shadow is enabled.
Posted: Wed Oct 25, 2017 12:12 pm
by archigraphe
It seems it is the solution....
AS the video is render, I post it.
in this time I 'm looking one machine with more Core.......
Posted: Wed Oct 25, 2017 12:58 pm
by RTD Laboratories
Hello!
It's hard to tell from the video alone, but my guess is that the render method itself is to blame. I'd suggest using an unbiased render, like
Interior or
Exterior, which should give you better results. Here's a quick test using the
Interior render at 25 passes:
- sun1.jpg (102.53 KiB) Viewed 13368 times
- sun2.jpg (99.06 KiB) Viewed 13368 times
- sun3.jpg (95.71 KiB) Viewed 13368 times
Hope it helps!
//Andrew
Posted: Wed Oct 25, 2017 1:45 pm
by archigraphe
Hello, thank you Andrew..;
As unbiased render seems to me very long... for an anim of 600 frame...
But for fix shooting it's a solution I'll experiment.
Nota : the render are doing in client office, so I'v very limited time for render the view.
Posted: Wed Oct 25, 2017 2:11 pm
Do not use any light emitting materials in animations.
Posted: Wed Oct 25, 2017 3:52 pm
by archigraphe
Ok all is fine in this preview.
I have corrected timin in animation under model information. there is trouble if I mention more time as the interval between scene..so some test were useful...
I'll work on specifique view for test, before start an all dim render.
https://drive.google.com/open?id=0B6hI4 ... zFUQ1JHemc
Posted: Wed Oct 25, 2017 4:54 pm
by archigraphe
Oh another trouble......
same project,
other plan view
red stone wall : materials : stone polished...
with easy 07 :
- EASY 07 red stone wall.jpg (229.24 KiB) Viewed 13353 times
all seems good....
with animation 03 Hight +: exactly same object, just change the render mode.
- animation 03 high+ red stone wall.jpg (240.46 KiB) Viewed 13353 times
What is the trouble???
Posted: Wed Oct 25, 2017 5:16 pm
by archigraphe
So I test with another model from me,
I think the Barcelona Pavillon, was not modeling very well.....I had to cleaning and recmposing it.....
Waste of time......
