rbissett
Post
by rbissett » Wed Sep 30, 2009 6:44 pm
Raytrace, custom...
- test_cust-low_sphersky.ornage_yel-lite_07s.jpg (46.62 KiB) Viewed 9271 times
- test_cust-high_sphersky.ornage_yel-lite_22s.jpg (37.5 KiB) Viewed 9270 times
Bob Bissett
rbissett
Post
by rbissett » Wed Sep 30, 2009 6:58 pm
Sky Color, gray, no light and then with light...
- test_02ambientocclusion_skycolor.gray_no-lite_14s.jpg (29.19 KiB) Viewed 9268 times
- test_02ambientocclusion_skycolor.gray_green-lite_22s.jpg (43.16 KiB) Viewed 9268 times
Bob Bissett
rbissett
Post
by rbissett » Thu Oct 01, 2009 5:24 am
Double convex, spotlight, Easy 10. Interior+, 18m30s
- test_2xconvex_spotlit_easy.10.interior+_nosoft_18m30s.jpg (70.03 KiB) Viewed 9258 times
Bob Bissett
- OS: PC 64bit
- SketchUp: 2016-2023
Post
by Fletch » Thu Oct 01, 2009 8:41 am
the last one is lovely
rbissett
Post
by rbissett » Thu Oct 01, 2009 7:09 pm
New render, discovered Exposure and Gamma...
- test_2xconvex_spotlit_easy.10.interior+_nosoft_39m00s.jpg (95 KiB) Viewed 9207 times
Bob Bissett
- OS: PC 64bit
Post
by Fletch » Fri Oct 02, 2009 7:54 pm
One thing I forgot to mention... in the video you linked to, it shows that if you paint the light component, it changes the color of the light.
This is the same in Twilight, but it's more advisable to change the color of the light using the Light Settings Dialog, as it affords you command of all lights from a single point, instead of wandering around large models looking for painted light components.
rbissett
Post
by rbissett » Fri Oct 02, 2009 9:20 pm
"...painted light components..."? Not sure what that is.
Bob Bissett
archigrafix
Post
by archigrafix » Wed Feb 03, 2010 5:57 am
today I was testing ambient occlusion in TWL so I wanted to know if it works in the real AO way or is it faked in the advanced02 setting. I mean can it be used to enhance shadow details like in other 3D package?
I did some test following your method (0 sunlight and sky mid grey) to obtain an AO pass and it works fine. But if I use usual sun and sky and adv02 setting, I see that it calculates raytracing but i cant figure if AO is also calculated and combined with rautrace calculations...
- OS: PC 64bit
Post
by Fletch » Wed Feb 03, 2010 6:54 am
in Twilight there is no AO pass that works in combination w/ materials as in some render packages.
the Ambient Occlusion pass in Twilight's Advanced settings was an experimental one, and is not well documented.
Users browsing this forum: Ahrefs [Bot] and 9 guests
