First Render: why is there a blue cast?
My first try: why is there a blue cast? Set at High+
- Aquarius Twilight.jpg (134.22 KiB) Viewed 11258 times
SU 7.1 and Win 7
SU 7.1 and Win 7
Re: First Render: why is there a blue cast?
Maybe you're using the physical sky, and the sky is blue. Try making the sun color a bit yellow to compensate, or just change the sky type to "Sky Color" (not Background color) and choose white.
Reset as suggested, but it just re-rendered the same thing (in 2m instead of 2 hrs). I had Advanced settings set to "All".
Registered version this time.
- Set to All
- Cell TR.jpg (109.15 KiB) Viewed 11181 times
SU 7.1 and Win 7
SU 7.1 and Win 7
If you can share the scene with us, email it to support at twilightrender dot com with issue and forum name in subject line
This is the same model (a little closer in and larger 1920x1126). It is only 55% antialiased as you can tell by the "jaggies" (8hr 18min) at High+ on an 8-core MacPro with 16GB memory.
I still don't really know what I'm doing, but it's enormous fun learning.
- Full Size 55%.jpg (723.23 KiB) Viewed 11120 times
SU 7.1 and Win 7
SU 7.1 and Win 7
Looks like the blue cast has improved. Was it just from changing the sky to white?
Hi Bob!
8 hours feels waaaaaaay to much for an 8 core...
check out this thread about reducing rendering time by using the proper lights:
http://twilightrender.com/phpBB3/viewto ... f=12&t=665
Cheers,
Adam
Adam
Chris,
Yes, Thanks.
Yes, Thanks.
SU 7.1 and Win 7
SU 7.1 and Win 7
All the lights are spotlights: aren't these supposedly the fastest?Pg09 wrote:Hi Bob!
MUCH to learn
P.S. and that 8hrs was only at 55% antialiasing
SU 7.1 and Win 7
SU 7.1 and Win 7
Most definitely... Spot- and point-lights are the fastest...Bob James wrote:All the lights are spotlights: aren't these supposedly the fastest?
However, I agree that 8 hours for a scene like this seem way too loooooong...
Your scene/model looks fairly simple and I don't see you've used any special materials or alike...
On an 8 core, this scene/model should render in less than 5 minutes...
So I really wonder why it takes this long...
Are you able to share the model/scene, enabling us to take a look at it...??
