Twilight renders a video almost as fast as SketchUp
The trick behind this seemingly absurd result is:
SketchUp uses only one thread during animation rendering .
I used IBL in Twilight to speed things up
Both tests rendered at 640 pixels wide (The SU one is 480px height, and the Twilight one is 425px in height. This was my mistake ).
Follow this link for higher quality:
http://www.youtube.com/watch?v=iNVqKh2k164
Re: Twilight renders a video almost as fast as SketchUp
good job I like TLR efect I hope that one day I'll find some extra time to play with the video
...fall down seven times, stand up EIGHT...
By the way, you don't see defined shadows in the Twilight test because I used an HDRI as the sole source of light.
I saw this on youtube, don't worry I gave you 5 stars!!
motion blur towards the end is fantastic
Oli
Miguel, I have a few animations to do soon, I normally use Max, LW, Houdini or even Vue for them, however if these do not need special particles or or 100% correct reflections, but more of a few product demo flv's.
Here is a link to an example of the qualty and animation I need to achieve, so my question is can your animation technique achieve this quality with a reasonable speed, then the next question (animation) is there a animation app out there that works with SU able to perform these movements?
http://www.groupelacasse.com/Brix?pageID=2282
Have you looked on 'proper_animation'?
I've heard of it, but never really investigated as I never thought of SU as a serious animation tool.
Thanks for reminder as soon as I'm done with current project i will try learn this and hopefully it will work.
There is also another... mover.rb (I think, never worker with these, just some SketchyPhysics).
I'm rendering a test with cmd's Mover.rb, will post results soon...
Ok, I did a test with scene transition = 2 seconds and another with 2 second. In both cases, the movement occurs in half the scene transition, leaving you 50% of motionless time... I still can't figure out how to make the movement span from camera to camera, as it happens in the SU viewport.
First test took 18 minutes to render in my i5 with "maximum threads", second one took around 7 minutes with only two threads selected. All were 640x480. I turned off the sun and used only a white sky as illumination. You might want to render an HDRI of your environment for this.
