The Twilight "Duh!" thread
I've just had a very big "Duh!" moment with Twilight Render. I noticed render speed was not what I expected, and then I remembered I had set it to only two threads for a test I did... last Friday. Duh!
So... have you had any "Duh!" moments already? Don't leave me alone here!
Re: The Twilight "Duh!" thread
lol.
Mine is everytime I change a texture and forget to unlink the last textures bump map, ending up with some screwed up looking surfaces.
Duh! So that's it!Solo wrote:lol.
Gai...
I seach everywhere on my computer where are the Twiligth images rendered but not saved !
(Podium saves automatically all renders so given me a Pavlov's reflex
but if somebody can give me confirmation i will be reassured
Forgetting to invert bumps (and you only realise it when you get up in the morning to have a look at your several thousand pixel wide image ready...)
Gai...
It's in the Manual.Pilou wrote:I seach everywhere on my computer where are the Twiligth images rendered but not saved !
If you are rendering on Easy 09 or 10, your temp image is saved here: C:\Documents and Settings\User\Application Data\Twilight\tmp_rnder.tmp
If you're rendering with any other method, then the image will only be saved automatically if you set this up in Twilight's Advanced Options (see Options section of the user manual)
- OptionsDialog_advancedoptions.jpg (32.59 KiB) Viewed 11014 times
Thx i am reassured
Aaargh!! I had a windows update and restart over night, and need to know where the last stored rendered image is on Vista 64. Hopefully I do not need to restart the render)
It's in your "local application data" folder.
So for Vista, something like C:\Users\your user naeme\Roaming Profile... something.
The best way is just do a search for "tmp_inprogress_image.png" (if you are using progressive method. If not... )
I'm an idiot!!
I started another render, so my progress is the last render...crap!!
Lost a 9 hour render... excuse me while I scream.
Users browsing this forum: No registered users and 26 guests
