Problem on picture
Problem on picture
Hi
First try, first problem: When render with Present 6 high i have something wrong on picture. This is not on Present 4 medium. What's wrong here?
When i istalled Twilight i installed it in SU7 (i habe SU6 and SU7 installed). When open Twilight i could not see any prewiev because the path was set on SU 6 and not on 7. I chanced this manually and it is O.K. now. Just to now for you.
- Problem.jpg (174.72 KiB) Viewed 10537 times
Re: Problem on picture
...and: Is it possible to scale or rotate bump texture? If not this is nessesary!
Whoa... that's a weird one.
If possible, would you mind posting the scene here or sending to support at twilightrender dot com?
There have been reports (not here, but on the Kerkythea forum) about blocks like that showing up, but I've never seen it look like that before! Were you running with more than one thread? Have you tried re-rendering it; do the problems show up repeatedly?
This is definitely one of the weirdest renders I've seen. It's almost like you were using multiple threads and one of them stopped working... You aren't using more threads than you have CPUs for, are you (ie dual-core = 2, quad-core = 4 etc)?
that is bizarre.
save file, close, restart sketchUp, re-render. see if problem persists.
if problem persists...
please send scene to support at twilightrender dot com
meanwhile, as I know you are an experienced Kerkythea user, try some of the technical settings - they are the Kerkythea presets.
For a tutorial how to work with bump maps, try this one on Realistic Water.
Basically, you unlink the color of the material, and link the bump to the scene's texture. Then however you position the texture in SketchUp is how you have just adjusted the bump.
I have this problem still and on 2 machines! Dou you need an xml or a sketchup file? I tried an KT PM Render Present and here no problem. And on TL in easy presents 3 4 5 6 7 and not only on 6 like i told!
sketchup skp please.
The problem is on all photon mapping settings even TL or KT sorry to tell you this just now
I have in office a 4 treads pc and at home 2. Use Windows XP. The same File works fine in KT even when i use TL Render Presents.
When i got the TL Licence can i insert this on both machines? I can only work at one in the same time
Have sent the link where to download the file today.
You'll need to request a key for each computer, where you want to install TWR...Zacchia wrote:When i got the TL Licence can i insert this on both machines?
But you're allowed to request two keys in one license...
Actually, that's for personal use. Commercial use is 1 license per machine.Frederik wrote:You'll need to request a key for each computer, where you want to install TWR...Zacchia wrote:When i got the TL Licence can i insert this on both machines?
So what, can i or not?
