House and Pool
Re: House and Pool
one more... think they'll like it?
the last one will be pure SU... I think. it's just an aerial axon
- Left-Pool-web.jpg (97.1 KiB) Viewed 9680 times
- PureTwilight-nopostpro-Easy08225passes.jpg (70.34 KiB) Viewed 9679 times
- Left-Pool-dtlclip.jpg (124.15 KiB) Viewed 9801 times
Re: House and Pool
by the way where did you get this amazing foreground foliage etc? stunning images sorry bout previous post i was in shock!
Oli
Re: House and Pool
I created nearly every image I used and nearly every texture. Solo may recognize his palms
I did not create the tulips... but I think I did make the mask for them.
I should have stuck with my hi-res plaster I created instead of switching at the last minute to SU's native plaster mat, but I have so many hi-res mats, this little job is a 40Mb SU file.
any version before SU 7.1 could not even handle showing me this file on my laptop
- SketchUp: SU8 to SU2019 Pro
Re: House and Pool
oli....how do you add a texture to the plants..?
Re: House and Pool
Show hidden geometry. Click on one of the triangles that make up the leaf mesh. File>Import>Image (use as texture etc) then apply that texture to rest of model by just shift clicking or projecting. this is only for 3d plants obviously.
check out this tutorial:
http://forums.sketchucation.com/viewtop ... ganic+form
Oli
Re: House and Pool
except for palms and off-screen plants, I pretty much photoshop the plants - they are faster and higher quality... if you know how to tonemap (use exposure tool in Photoshop) an image well, you can 'match' a 'mood' of lighting in almost any image.
In Photoshop - go to >Image>Adjustments>Exposure
same with how I added the natural-looking dirty streaks on the plaster - post pro...
Re: House and Pool
last but not least... the axon.
using Animation>Low+ setting and some photoshop filters. this was a "freebee"
- Axon-DigitalWatercolor.jpg (115.24 KiB) Viewed 9598 times
Re: House and Pool
Great, Great!! I am now becoming an admirer and a fan of others' works/renders. I enjoy watching images/renders of great renderers like you. I hardly get any time for 3d work because I am so engrossed in the design process. So I now keep enjoying the works /renders from Twilight and Kerkythea.
Thanks Fletch for your offering to share the stone material someday!
With best regards
PRSS
With best regards
PRSS
