Processing had errors...
- SketchUp: 2014
Re: Processing had errors...
So I am here at work thinking that my version of TR is not the most recent but it appears it is. 1.0.19
What is odd is that at home I see a preset 11 Progressive Prelim (I think it is called) but at work I don't have that. But both are 1.0.19
I must not have installed something. Odd. It is not hindering any workflow, just odd.
I don't have that one mine either, even thought it says that it's the 1.0.1.9 version.
I asked a question similar to this before with no response. I think it was Miguel saying that I should look at a preset for an Alternative AA but I'm not showing that in any of the render listings. I just did an upgrade install.
this may come as a shock, but I do not yet have everyone's systems/operating systems memorized.
It may be a Win7 thing or something... I'm not sure.
Please Try this:
close SketchUp
temporarily rename your Plugins/Twilight folder to be something like
"Plugins/RecoverPreviousVersionTwilight"
Then download a fresh new copy of the 1.0.19 install file
Install it
Open SketchUP
Open Twilight Render Dialog
Look in render settings and see if it looks something like this now...
Now, go to the "Plugins/RecoverPreviousVersionTwilight" folder and copy any special materials or settings you had in there back over to the fresh new Plugins>Twilight folder.
You should not, after doing this, need to re-install your license... let me know if I am incorrect. (be sure you back up your license file someplace... it's called .lic
I believe after .19 update the .lic file is no longer stored in the Plugins/Twilight folder.
- rendersettings-release019.jpg (80.66 KiB) Viewed 11147 times
Fletch, thanks for the help I'll give that a try and let you know.
I'm on windows xp.
surprised you didn't know that... thought you were a telepath.
I'm on windows xp.
It would help if we could display our SketchUp version and OS under our nicknames, like the SCF does.
What, like this then --------------------------------->
That worked Fletch, Thank you!
I didn't have to re-install the license.
- SketchUp: 2014
Sadly it did not work for me. Furthermore I had to copy the .lic file from my "recover TR" folder to the new Twilight folder for it to go from Demo to Standard. Really odd IMO; and I am still experiencing this on my home machine but not at work.
- 19.jpg (130.43 KiB) Viewed 11096 times
Do you run SU 6 and SU 7 on the same machine? Or SU 7 and SU 7.1 separately? Twilight uses the same options file for all installations of SU. So the path to the render settings is the exact same path on all installs. I suggest going to Options -> Directories and checking the path for your Render Preset Directories and making sure it's the one you want (IE Sketchup 7).
- SketchUp: 2014
That did it Chris, thanks.
Here at work we have SU6 pro but 7.1free, we have not made the upgrade yet so I was running it on both. I believe at home I am only running it on 7.1 pro, will have to check tonight.
Thanks again.
Thanks again.
