Help! Rendered Animations
- SketchUp: Pro 7.1
Re: Help! Rendered Animations
The only windows are perspex roofing lights and the client has specified that they don't want a feature made of them. I've heard the word global illumination before...will this help or have I mis-interpreted?
Check out my site:
http://www.coastalconcepts.org
Global illumination is built into pretty much every Twilight preset. Basically it means that indirect light contributes to the lighting of your scene. So sun shining through a window into a room will illuminate all around the room, even if it doesn't have direct sunlight on it.
If this is indoors, I'd suggest omni lights where you'd expect to place lights normally. But that's definitely not my expertise. Maybe someone else can give good, but fast, lighting suggestions.
- SketchUp: Pro 7.1
When you say Omni lights do you mean point lights etc?
Check out my site:
- SketchUp: Pro 7.1
Cool thanks for the help guys, much appreciated
Check out my site:
- SketchUp: Pro 7.1
On a side issue, has anyone ever encountered this problem with getting light speckled textures in a building?
- internal lighting test.jpg (184.1 KiB) Viewed 9485 times
Check out my site:
This thread may help
http://twilightrender.com/phpBB3/viewto ... f=12&t=732
this may also help:
http://twilightrender.com/phpBB3/viewto ... 7065#p7065
this may also help:
You may want to try the "Animation" render settings on this scene! They will likely avoid the "sparkles"... but render times will go up a little bit.
The Light Through A Window thread, may help explain some lighting things...
and just created this thread which may help explain some things about render settings...
- SketchUp: Pro 7.1
Thanks very much for the help Fletch, that lighting info will be great.
Hey by the way, I have 2200 frames to render in an animation, set at 'low' each frame was initially taking a minute or two to render. I thought I would have my render done by the deadline quite easily. However, I have gone away and expected to come back to an almost complete render but the render time per frame has jumped up to over 5 mins per frame, there is no way I can make the deadline at this rate. Why was there a change in frame render times? Is there anything I can do to amend?
As always, any help is much appreciated.
Ash
Ash
Check out my site:
- SketchUp: Pro 7.1
BTW it seems to be the antialiasing portion of each frame that is taking the most time.....
Check out my site:
Users browsing this forum: Ahrefs [Bot], Bing [Bot] and 7 guests
