Hello,
I'm completely new to rendering and stuff related to it.
I have been sketching some interiors in sketchup and want to make it look more realistic with twilight render.
I use the option: 9. Interior for rendering my images, it takes a long time to load ( i never complete all of the 10000 ray tracings). And they look good on my computerscreen, but when i try to print the images it only shows a small part of my sketch. Is there any solution to this?
Kind regards.
Printing rendered Sketchup images
Re: Printing rendered Sketchup images
All progressive render settings Easy 08 - Easy 11 are meant to be stopped by the person doing the rendering whenever they deem the rendering to be "complete". So you can obviously stop the image from rendering at any time. If you use the Fast Forward Denoise plugin for Twilight, it will eliminate the noise quickly, and will reduce render times cutting them to less than half or a third or even more (depending on scene/lighting situation).
Please show us what you mean, it is not clear what this means.
Please describe step - by - step your printing process.
Thank you for your reply.
My process is: save the render by clicking save as. I usually mail the image to myself so i can view it on my phone or any device that i use. This works and the image i rendered is dully shown. But when i try to print the image there's a lot of parts missing from my image. I tried multiple printers, but got the same result. I've read something about changing DPI or something, but i don't even know what that is.
Greetings
Greetings
Please post screenshot of the printing dialog box for your printer just before you send the file to print.
The dialog should have a "scale to fit paper" check box.
You are the first person to ever ask this question, so be encouraged that the image can be printed just fine. It's just a matter of learning how to do it correctly.
