M1 to V2 Update
Re: M1 to V2 Update
Will this do?
- Translucent.zip
- Material Library
- (294.44 KiB) Downloaded 479 times
Re: M1 to V2 Update
No, the SKM libraries have nothing to do with Twilight Render. They are only for the use of SketchUp.
Your screenshot shows 4 materials that have invalid material data in them. Presumably these were failed imports when converting from V1 to V2 from an existing KT/TWL material library. Do you have the KT/TWL material libraries that these materials were assigned to?
If you have questions about which library was used for each of those materials:
1. Open the Twilight Render V1 Material Editor
2. Under the From Scene menu choose each of the materials with problems
a. Material60
b. Material61
c. Translucent_Glass_Blue
d. Material80
3. Observe and record exactly what Library and Library-Material was being used for each of the above materials in V1.
a. Material60
b. Material61
d. Material80
Re: M1 to V2 Update
It says that "there are too materials in the scene to open". But, the best I can tell they are located under plugins/twilight/materials/translucent.
