Hi, i work for a model, during one month and im so close to finish, but suddenly TWL render stoped working. there is an image.
can you help me?
Render failed
- SketchUp: Sketchup 2020
Render failed
- kucha 3.jpg (2.83 MiB) Viewed 6672 times
Re: Render failed
Hello Melk-ART-e,
First, purge the file using Purgeall.rb plugin.
My first guess would be that you are running out of RAM. Please watch the RAM usage (if on Windows press SHIFT+CONTROL+ESC at same time to see task manager before you render.) Close your internet browser and all non-essential programs before rendering.
Without PRO version you cannot run Diagnostics, but if you had PRO you would do that first.
You can open the LOG file before you start the rendering and post the information from the LOG file here.
My best educated guess is that you have added something into your scene that is a bad model likely from the 3D Warehouse.
If you have added a high resolution spherical sky, use physical sky and see if the scene will render.
You can perhaps figure this out by putting all of your 3DWarehouse content on layers and TURN OFF those layers, and try rendering. If you can render the scene with those objects "OFF" then you know the problem is in those objects.
- log.jpg (45.11 KiB) Viewed 6665 times
- Untitled-1.jpg (49.05 KiB) Viewed 6664 times
Re: Render failed
i tried all your suggestion, also i bought new ram. my pc specs are, i5 - ddr3 with RAM 8GB 1600 mhz. Video card GTX 650.
is this specs normal if no? im in final but can not finish my model
Re: Render failed
Well, you have not tried all of my suggestions,
8GB of RAM may be ok, but honestly 16 is better for large scenes like yours and 32 is best for large scenes.You can open the LOG file before you start the rendering and post the information from the LOG file here.
Clearly something was added to the scene at some point that is causing the failure. It is not possible to guess what that is.
It has happened several times that a strange texture format or strange name of a texture can cause a failure. This happens with imported geometry from 3D warehouse sometimes.
Only thorough testing can reveal the problem.
1. have you tried rendering only a small portion of the scene, for instance, even render only a single object like one building, yet the scene still fails to render? Then add back one or two objects at a time testing rendering ability each time?
2. have you replaced the sky with physical sky and it still fails? Will it render if you hide all geometry and only render the sky? If it still fails, then there is clearly a problem piece of geometry or file or texture in the scene and you will need to identify where it is.
3. have you systematically eliminated all geometry from the scene, rendered a test image, then slowly added back (enabled visibility of the layers) of the scene geometry piece by piece until hitting the failure point?
4. have you tried starting a clean new file, and copy-paste-in-place items one-by-one into the clean new scene and run small test renderings until the scene fails?
5. have you applied light emitter to curved geometry? If it is applied to too many faces it can fail.
Re: Render failed
i know what is good and what is best too. okey i found the reason. it was PNG format image using as emitter.
Re: Render failed
This should not have caused the problem - we will have to test - but please send us a small file containing only the problem image so that we can bug-fix bug-test.
