I'm running a new Mac M1 with onboard video. Anyone have a clue if the denoise plug in would work on that setup?
Thanks
Denoise on M1
Re: Denoise on M1
Running Twilight Render on an M1 processor in general requires that you run SketchUp using Rosetta.
Assuming you have done so and Twilight Render works, you should be able to run FastForward Denoising in CPU mode. In case you need more info on the Denoiser in CPU mode, you can read about it in our tutorial here: https://www.twilightrender.com/index.ph ... -denoising
The Denoiser will not work in GPU mode. It can only run in real-time GPU mode on Windows with supported NVidia hardware.
Users browsing this forum: Bing [Bot] and 1 guest
