Alphabet inspired sketches
Re: Alphabet inspired sketches
This is amazing as I see that you have developed the initial concept from the very early stage!
Thank you.
I think it will take a little time as I have several thoughts/ideas in my mind that I will need to think through.
To anyone considering the book that comes from this source thread, I got my copy today via Amazon and it has a huge amount of inspiration to assist in waking up the thought process.
I definitely rate this book highly and already have so much buzzing around my attic, it will take a while to go through them all.
In short, get it, You will be happy you did.
https://www.amazon.co.uk/ketches-sketch ... C89&sr=8-1
Could not agree more. I have gone through my copy many times and still look at it often. It is very inspiring.
Once again, to Majid
Wow, mates, Mike and Dave...
I am overwhelmed by your comments and am happy you have found it inspiring.
I appreciate your support
Mike1158 wrote: ↑Thu Aug 03, 2023 10:56 pm To anyone considering the book that comes from this source thread, I got my copy today via Amazon and it has a huge amount of inspiration to assist in waking up the thought process.
A, E and X.
The 'A' frame crossed to form four arms, to which apartments are attached, I know, not all the supporting framework is in place. Just sorting out the lie of the land.
Viewed from the top, the 'X' will be evident while decor on the outside of the apartments will initially be the 'E'.
I need to work out where the bungee cords, sorry, lifts and stairs will go but probably two of each.
- Alpha Betcha Noo Too.jpg (114.88 KiB) Viewed 24600 times
You are finding tour own way!
Ta mate but, yes, always mine own way.
That is meant to be a whatif of apartments, a little craziness if you will. There is a central lift shaft etc but no stairs yet, or ever perhaps.
The fire escape method consists of a bungee cord system and the user just steps out of the building wearing the harness.
They will of course have to unclip the harness the moment their feet touch the ground and it could get messy if there is anyone above you when that happens. You might also need an umberella in that case too.
No, it rhymes with Mooo.
- Alpha Betcha Noo Trio 9 24p 19m.jpg (148.24 KiB) Viewed 24551 times
Wow, makes me feel old fashion with one I am working on. This one is “out there”.
