Hey guys!
Just made an account today. Love to see what others are doing with twilight.
Quick problem for you guys!
I have been rendering in interior+ and have been getting really spotty results. There are tiny dots everywhere. Wondering if anyone has had the same problem?
I've never taken any courses for this kind of stuff so maybe I'm just missing a fundamental I don't know about...
Check the photos! I feel like I'm really close to a good render but these speckles don't go away...
Thanks in advance
noisey Render with Interior+
- IMG_20210331_121257_580.jpg (609.93 KiB) Viewed 5096 times
- downfire2-01.jpeg (824.84 KiB) Viewed 5096 times
Re: noisey Render with Interior+
Interior+ will need a very high end computer to clear quickly.
You should render with Easy09. Easy 10 is for rendering very technical images like lasers split by prisms, etc.
It does look very good, other than that. Easy 09 should get you a nice image in half the time. But both Easy 09 or 10 require as fast CPU as you can get. 8-12 threads will be much better than 2 or 4.
With Twilight Pro you can buy the FastForward Denoise addon and it will reduce rendering times greatly (works with NVIDIA graphics cards or Intel CPU) In my experience renderings are ready in much less than half the time when using FastForward.
Please follow the Video Tutorial series "6 Essentials to rendering with SketchUp and Twilight Render" linked in my signature below.
Here's an image I worked on today. This helps you see the power of Fastforward addon, and also to use the ACES post process button.
- Introducing-Unsharp-Mask-For-Twilight-Render.png (2.25 MiB) Viewed 5079 times
Thanks a lot Fletch!
Switching to Easy 09 did the trick. took a while though. Ill check out that plugin!
